Problm with print pdf
I created this dyn for print pdf. I selected three sheets and saved as a set and I selected that set but when I run the program only one pdfis printing and how to export pdf with the same sheet name ?
thanksPRINT PDF.dyn (7.1 KB)
I changed the location
but the name is coming as test only one file is exporting I selected 3 sheets to export … how to export with the same sheet number?
CAN SOME ONE SHARE THE DYN FILE FOR PRINT PDF WITH THE SAME SHEET NUMBERS>?
Hi!,
When I use local printers names in Revit 2017 I get an error, in Revit 2016 it work perfectly.
Does anyone else have the same problem?
I use Dynamo 1.3 (the latest)
