Problems with units when exporting from Dynamo to Robot
I have a problem when exporting the geometry from Dynamo to Robot using the Analyze package. My units in Dynamo is in millimeters, and the export to Revit Works perfeclty fine:
As you can see, the units are both in millimeters.
But when I try to export the Dynamo geometry to Robot, it always appears in meters. I tried to change the units to millimeters in Robot before running the Dynamo script. But it just appears in the scale showed in the Picture:
Robot just adds 10^3 to my dimensions.
Thanks for any help!
Hi @571488
Try to save your mm units in a template and close both the robot and dynamo and reopen them
I used to have a similar issue and every time I had to repeat my analysis I had to break the connection between dynamo and robot by closing and reopening them
I hope this could help you
Regards
Hi @Jaafar_Al_Nasire,
Thanks for the reply!
I have tried to save a new Robot template With mm units. Then i closed the Robot template (Shell Design) and reopened it. I runned my Dynamo script and the Geometry appeared in both Revit and Robot. The Revit modell works just fine as before, but the Robot model is still in meters… Do I have to convert my output With a node or something, when exporting my model to Robot? I thought this was going to work… Strange…
Or is it any problemwWith the template i am using (Shell design)?
Thanks again for any help!
Hi @571488
can you send me you Revit dynamo robot files?
I just converted the units from millimeters to meters in Dynamo, before sending the model to Robot. It Works just fine!
