I’m having a lot of issues with Dynamo on Revit 2020.
I was on R2020.2.2 and experienced these problems - have updated to 2020.2.3 and have the same problem. I believe things were fine with earlier builds, but wasn’t doing a lot of Dynamo at the time.
Revit 2019 and Dynamo 2.0.4 works fine.
Essentially Dynamo opens fine, but after a little while, or if I run a graph, just starts graphically glitching.
Varying degrees of not being able to select menus and nodes, run graphs, search for nodes etc.
If I close Dynamo and re-open I get the following error:
Restarting Revit allows me to access Dynamo, only to have the same issues within minutes.
I have tried:
- Updating Revit build as mentioned above
- Cleaning out appdata files
- Removing all packages
- Starting with a clean graph.
Anyone with any ideas how to resolve? I guess I am staring down the barrel of a full Revit 2020 re-install, but would prefer to avoid it if I can.
