[Problem] "Wall Sweep on Wall" Node Problem
Hi!
I’m using the “Wall Sweep on Wall” of Data-Shapes package. I’m creating vertical wall sweep on 4 walls. But, there was a problem with final wall (highlight in image).
Please help me solve this.
Thanks and kind regards.
Wall__Model_Multiple_Meji_by_Select_Walls.dyn (37.6 KB)
after some tests, the vertical distances for the node “WallSweepOnWall” seem to be set from the origin of the face and not from that of the curve of the wall (StartPoint).
And the origin of the face and the origin of the curve are not necessarily the same
an example
sweepbyUV
import sys
import System
clr.AddReference('RevitAPI')
pf_path = System.Environment.GetFolderPath(System.Environment.SpecialFolder.ProgramFilesX86)
sys.path.append(pf_path + '\\IronPython 2.7\\Lib')
import math
wall = UnwrapElement(IN[0])
start =IN[1]
step = IN[2]
out = []
ref = DB.HostObjectUtils.GetSideFaces(wall, ShellLayerType.Exterior)[0]
face = wall.GetGeometryObjectFromReference(ref)
bbxUV = face.GetBoundingBox()
uMin = bbxUV.Min.U
uMax = bbxUV.Max.U
# convert decimal feet to Millimeters
uMin = int(math.floor(uMin * 304.8))
minfactor = 1 if uMin >= 0 else -1
uMax = int(math.floor(uMax * 304.8))
maxfactor = 1 if uMax >= 0 else -1
for i in range(start * minfactor, uMin, step * minfactor):
	out.append(i * -1)
for i in range(start * minfactor, uMax, step * maxfactor):
	out.append(i * -1)
# remove duplicate
out = sorted(set(out))
OUT = out
resources
Wall_Sweep_Model_Multiple_by_Select_Walls.dyn (32.1 KB)
