Problem using nodes in Dynamo sand box
Error message containing a file not found warning !
Thank you for your help.
RG
@rgarciaM3V9C , hi
which version do you use? i use 2.14. … in my eyes it`s relative stabile! only NumberSliders have a bug! :wink:
KR
Andreas
Thank you for your reply.
I use 2.16 and many node don’t work.
Have a nice day
RG
To use geometry within Dynamo Sandbox you still have to have a Autodesk software installed because of the licenses relating to geometry kernel.
@Brendan_Cassidy ,
one revit has to be installed, it is sufficiend - even when you can`t open it - because of a missing licence.
also forgot to add, did you follow the “Unblocking” of the zip file prior to unzipping the file?
Thank you but the problem persists
Dynamo sand box does not install: I have to launch DynamoSandbox.exe to open it, is it normal?
@rgarciaM3V9C ,
Do you have installed Revit 2023 ?
Yes
