I need to make a file name with several parameters names and im not sure how to do it.
I have 9 parameters that i need to join and so just 1 index for the file name.
anybody can tell me?
My other problem is that im trying to print the pdf’s and the first time worked and then nothing! @Alban_de_Chasteigner im using Genius Loci, maybe can you help me a bit?
Do you need the values to name the pdf? Is that correct? If it is the case try to make string from the values and use the string concat node to join them.
These are more robust when the list of incoming strings is of undetermined length.
The first is fast, but hen you need to parse out the [ and ’ and any extra spaces.
OptionB is easy to add in the “\” you’ll need for the directories.
