String from list node does not accept string as suffix and seperator
Hello all, there is probably something i am missing…
See below: I am trying to create a string by combining several lists with a dash as seperator and a .pdf as suffix.
For some reason this doesnt work anymore, it does work in 2018…
I am using Dynamo 2.3 and revit 2020
Edit…
I think the problem is that the list combine node gives multiple lists?
Would be better if you show us your initial List and the expected output.
However, from what I could understand from your images, see if this works for you.
Looks like a lacing issue with the single inputs for the bottom two. Try setting it to longest if @Vikram_Subbaiah solution doesn’t work for you.
I am sorry for taking so long to get back to this post.
Your solution worked perfectly!
Hi MVE112,
Where do i get “String From List” node
Thanks in advance
Hi YUGANDHARREDDY.IPPAT and welcome!
You can find the String from list node in the Archilab package.
