Print PDF and export DWG same time
Hi all .
I try to write this dynamo for print PDF and export DWG same time .
Hi @thuanamd,
Please zoom into a single node and use the camera icon in the top right corner to capture your screenshot because your picture isn’t readable.
What is the mistake that you encounter ?
Thanks for viewing .
I resend screenshot for zooming into single group . I use printer name is PDFCreator because it help me to merge all PDF from sheet after being finished .
I edit Python Script of Export CAD to add OUT = 0 first and OUT =1 when done for RunIT of Print PDF ( replace Passthrought ) .
I changed DWG export options Color to TrueColors to avoid making files *.pcd after export DWG .
But I have trouble in Dynamo 2.0.1 . Why is it making duplicate output of Print Setting and Print Range after saving Dynamo file ? Please help me about that .
This problem has already been encountered earlier:
Check that the package archilab is up to date.
I have already updated Archi-lab.net package to 2018.13.13 in Revit 2017.2 and Dynamo 2.0.1 . But the problem hasn’t been solved .
Having the same trouble here. Following this topic and hoping for an update!
it worked?
You must wait for an update of the archi-lab package.
Yes , it worked .But I am waiting for updating some packages to dynamo 2.0.1 . After that , I will upload finished dynamo file .
As anyone been able to successfully accomplish this script?
You can use archilab and Genius Loci packages for this task.
Start a new topic if you encounter errors.
