If I understand correctly, the Dynamo graph has a persistent link to the objects created in Revit.
<div class=“ytp-copytext ytp-no-contextmenu” tabindex=“1”>https://youtu.be/ItTL546nGfs?t=688</div>
<div class=“ytp-copytext ytp-no-contextmenu” tabindex=“1”></div>
<div class=“ytp-copytext ytp-no-contextmenu” tabindex=“1”>What happens when a parameter is changed on the Revit side? I would expect that any changes on the Dynamo side will result in any geometric parameters being changed as the graph is re-run, but non-geometric parameters would be preserved?</div>
<div class=“ytp-copytext ytp-no-contextmenu” tabindex=“1”>For example, one of the ribs in Zach’s vid could have its rendering material colour changed in Revit. Would this be preserved or would this have to be done in Dynamo?</div>
