Hi All,
Just wondering if dynamo has the ability to create,read and update a parameter within a session of Dynamo.
Usage example as follows:
- On first run of script, parameter is set to a value of 1. Script uses this value to set True/False Boolean within the script.
- On second run, checks if parameter exists and if it does, doesn’t create it again, but reads the value and interprets this to change the true/ false Boolean before setting the parameter value to 0.
So that each time the script is run it reads the parameter and adjusts the workflow accordingly.
Alternatively, a parameter in Revit could be set and read, is this the work around?
Is so, which would be suitable?
Any advice is appreciated.
