I was wondering if there would be a workaround (dynamo, api or other) about updating existing materials and their keynotes when the structure of the specifications changes.
Itâs more with the idea of there would be a (new) material (or more) that donât have an assigned keynote or a wrong one. I was thinking to start creating an Excel file where a comparison between the old and new would be made. Using the existing master keynote list (in excel format) + all materials that the office uses. Bringing these two sheets together in a third sheet. Then having an additional sheet that would list all new or conflicting materials/Keynotes. And finally a sheet that would be the base for sending the corrections, info/data, back into Revit.
Would such concept work IRL?
Is it possible to automate the assigning of a keynote in the material identity tab ? (that should have been the title, I guess)
Yes - such a concept can work in real life.
Including a new material parameter for âUnique IDâ would be recommended as mark can vary across projects (i.e. if youâre using wood 3 but not wood 1 or wood 2 you might want to change the mark for wood 3 to WD1 instead of WD3).
