I try to make Graph that would allow by using Dynamo to change elements keynote parameter in Revit imported from excel.
It seems working, but I Why it adds 000 in Node:String from Object?
There is a six digit precision on doubles, and the added digits are being added to hit that value.
See what happens if you use the ‘read as strings’ input of the excel node as ‘true’. You could also remove the trailing zeros of the string, or just format the data as strings in excel.
JacobSmall. You are Solver numero 1! ![]()
Thanks you
