I have a simple Dynamo script with some color overrides in Python and reading an excel file. This has been working fine, but today I tried to open it and it gave me this Error. The file will not allow me to open the file. Can I force open the file. How would someone salvage a flow if the file is locked?
This has started to happen when I started using 2.0
This the message which only allows me to click ok.
Here is one of the files I can’t open.
KR - COLOR.dyn (163.0 KB)
@Danny_Bentley the file isn’t corrupt, someone upgraded it to 2.0.
Run it in 2.0 going forward or check the backup folder for a 1.3 version (though it says you wrote it in 1.1 so maybe the 1.1 version).
Sadly it will not open in 2.0 or 1.3. I don’t have 1.1 installed. There must be a way to open it. I understand if some of it is deprecated, or corrupted but should allow us to salvage the flow and python to move into a clean .dyn file.
I managed to get it open doing the following:
- Open the file in a text editor
- Change line 3 value to true.
"IsCustomNode": true, save and close
- Change the file extension to DYF
- Drag into Dynamo 2.0
It seems that there was some weird error regarding notes with the same GUIDs.
I removed all the notes and here is the graph:
KR - COLOR-fixed.dyn (160.3 KB)
John, I could give you a big hug right about now. Thank you for the help. It worked!
Hi John! I’ve tried to get the same results you managed to get, but to no avail! Here is my DYN file wish you can help.
Thanks !
POLYLINES TO C3D PIPES.dyn (131.5 KB)
@Ahmed_Ramy the issue was here:
This should read:
Changing this in a Text editor will solve the issue
@Ewan_Opie Thanks Ewan for helping out as the solution has worked! I am only wondering what this line means??
