I have problems finding the .dwg I’ve imported. I also tried to link it, without further luck. I have tranformed the .dwg so it has the same coordinates as my model, it should end up in the same place. I have checked the manage links function and the .dwg is there somewhere…Could use some help
When you Import or Link the DWG in Revit, it doesn’t show up in the View? So this is a Revit problem not a Dynamo one?
I’d start by checking the scale of the DWG. What does one unit represent in AutoCAD, and what settings are you using in the Revit Import / Link dialog?
