I have a huge problem with the import dwg / link dwg nodes from the Genius Loci Package. In my opinion both are pretty much doing the same, but the outcome is different.
Import dwg uses the “doc.Import”-Method, Link dwg uses the “doc.Link”
Link-Method - https://apidocs.co/apps/revit/2019/f3112a35-91c2-7783-f346-8f21d7cb99b5.htm
Import-Method - https://apidocs.co/apps/revit/2019/1b1413fd-1358-709b-77a8-e383d6c1301e.htm
I use the same settings for both of the Nodes. When executing the functions the DWG Import works fine. Every item gets rotated to view and looks perfectly. My problem is that I need the Link Element Node which places the Links on the views, but these are not placed properly. Sometimes, they are rotated to view, but most times, these are rotated, some even arount 180°, so they appear as mirrored files.
Does anyone know how to solve this problem, I already spent hours on it and came to no solution
Thank you so much!!
_link_dwg_files.dyn (28.7 KB)
