I have been working on a code that works with some curves, joining them into polycurves and working with these polycurves afterwards. This workflow was fully working on DynamoStudio, but when I try to do the exact same thing in Dynamo SandBox or Dynamo/Revit I am finding the following issue:
Polycurve is joined correctly with no errors, but when I want to reverse that polycurve or find the closest point from the polycurve to a point, the program deprecates all the curves composing the polycurve but one.
I can’t really share the file, sorry. Yes, the three segments that compose the polycurve are the ones that I have joined to create it. Usually in Dynamo Studio there is no issue with that, but in this case I really don’t understand why, whenever I try to work with those polylines it deprecates part of it
Personally, I can’t really help without seeing how you got here. I had a few thoughts as to ‘why’ it’s happening (inline points, geometry working ranges), but none of them panned out in my examples. Since I can’t recreate the issue I’m unable to help.
Removing all but one of the failing polylines from the file should remove any concerns you have with sharing, and should allow us to see where the issue is.
