Method 'PolyCurveByJoinedCurves does not have an implementation
Hi, how are you?
I’m trying to venture into the dynamo’s paths … but I find it very difficult when a bug happens.
Does anyone know what’s going wrong?
*> Polygon.ByPoints operation failed. *
> Method ‘PolyCurveByJoinedCurves’ in type ‘Autodesk.LibG.GeometryFactory’ from assembly ‘LibG.ProtoInterface, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null’ does not have an implementation.
Revit 2019
Dynamo Core 2.0.26826
Dynamo Revit 2.0.26833
dynam|690x464
Thank you!
Could you show us your complete graph with all the previews on.
Follow the graph, thank you very much.
I’ve tried the Dynamaps, and it’s happening the same. The same error.
What does error says? Could you show watch node at points and polygon.bypoints node?
Possible to share osm file here?
The files are on those links.
https://villagebim.typepad.com/files/villageosm-1.dyn
https://villagebim.typepad.com/files/smlr1.osm (File from which the data is taken)
But following this tutorial from Dynmaps, the same error occurs.
https://dynamobim.org/dynamaps/
Warning: DynaMapsNodesFunctions.LiveTopoPolySurface operation failed.
I searched a lot on the internet for some solution, but I did not find it.
something is loading an incompatible version of the geometry library perhaps.
  1. Do you have any green notifications in your dynamo menu bar?
  2. Can you share an image of your dynamo core folders? Look for LibG_xxx_
  3. what versions of dynamo are installed on your system - look in control panel
  4. what version of Revit 2019 is this?
Hi @Peleias
Thanks for sharing your files. I just tested your files and it works as expected for me:
revit file attached For Peleias.rvt (1.4 MB)
Thank you! After his comments I noticed that the problem was of the dynamo. Uninstalled with revo unistall. And I downloaded and reinstalled everything and it worked!
Thank you, the problem was in the dynamo.
