Placing switches near doors
Hi all , I am trying to write a code to place switches near the doors(200 mm away from door and 1200mm height).As an initial step ,I’m getting the location of door and trying to translate point to 200mm after adding the half width of door.Now I am stuck to find a vector along the wall to translate the point along the direction as desired.Any help?
UIunit = Document.GetUnits(doc).GetFormatOptions(UnitType.UT_Length).DisplayUnits
Door = UnwrapElement(IN[0])
# Place your code below this line
Location_Point = Door.Location.Point
Door_TypeId = Door.GetTypeId()
Door_Type = doc.GetElement(Door_TypeId)
Para_Width = Door_Type.LookupParameter("Width")
Para_WidthValue = Para_Width.AsDouble()
Para_WidthValueInmm = Para_WidthValue*304.8
Width_Half = Para_WidthValueInmm/2
HostWall = 	Door.Host
Location_Curve = HostWall.Location.Curve
Vector_ = Location_Curve.Direction
pt_Dyn = Autodesk.DesignScript.Geometry.Point.ByCoordinates(UnitUtils.ConvertFromInternalUnits(Location_Point.X,UIunit),UnitUtils.ConvertFromInternalUnits(Location_Point.Y,UIunit),UnitUtils.ConvertFromInternalUnits(Location_Point.Z,UIunit))
OUT = pt_Dyn,Vector_,Width_Half
switches Testing.dyn (14.1 KB)
replace this line by
Vector_ = Location_Curve.Direction.ToVector()
see here
Thank You.
