Hi guys…
i have just started using Revit/ Dynamo after spent couple years in Rhino and a little bit of Grasshopper.
while i 'm working on Revit with Adaptive component, i found that would be great if i can set up dynamo to place adaptive component to save my life.
basically, what i have done is… i have created nodes by intersecting between floor lines (Levels) and panel module lines (at the bottom of building) and i have placed 4points, 3points, and 5points adaptive component manually for these all elevations of building which was very painful.
below left side image is what i have done manually, right side is the attached file.
i know how to do similar thing in rhino / grasshopper but since i’m very new to dynamo, if somebody can guide me, that would be greatly appreciated.
eventually, i also like to divide surface using dynamo as well. but i think this is my first step.
Dynamo Mass.rfa (816 KB) Typical Panel_Glass_Mullion_3p.rfa (404 KB) Typical Panel_Glass_Mullion_4p.rfa (428 KB) Typical Panel_Glass_Mullion_5p.rfa (404 KB)
