Place Family by Points (from Excel)
I am trying to place a family to several points, which are listed from Excel.
Family Type is Spring.Collected from model.
Do I need to convert the list of points (output – item)–>to list with geometry output? Is there a way to do this?
Also, Family Type from Spring Collector Filter has ID #, and it is placed only once, when I am trying with nodes "for testing”
Thank you!
Please see below:
Hi @Vera.Anichina
What happens when you run did it placed all of them? Could you show watch node @ “FamilyInstance.ByPoint”
Hi @Kulkul
When I run, it doesn’t place anything. Comes out with Warning.
And only one item placed when I use List of points with geometry output
It looks like your Family Type input is a list of a list. You might have to flatten it or try setting your lacing to Longest.
