Place and Array a cad block on a linear path of a polyline!
Dear all,
Any one can help me with the following? I am trying to create some basic Dynamo Script to ARRAY a Simple CAD-Block on a linear polyline path. Please check the attached screenshot. BlockRefernce.ByCoordinateSystem indicates a constant error, please check the screenshot.
Thank you so much for your help and support.
Kindly regards
Salwan
Hi @S.Abbosh,
The issue is that the Document.BlockByName node is returning a null output, which will propagate through to all of the downstream nodes. Make sure that the name of the block is spelled correctly.
Dear Zachri,
Thank you so much for the answer and the time you spent helping with my dynamo topic. After checking the block spelling, everything went perfectly. Now, I am facing another challenge! :wink:
I was trying to import a block from an external DWG file, but unfortunately, I could not achieve that goal! So I just want to know what I missed importing an external AutoCAD block from an external DWG to my current file.
lots of thanks for everything
Kindly regards
Salwan
Please open a new thread for this as it is unrelated to the original topic.
