Im trying to place an adaptive component using 2 points. Somehow its not working. Can anyone see what Im doing wrong?
The adaptive component Im using works fine in Revit.
See attached image.
Wouter
Hoi Wouter,
Is your curve a straight curve or an arched one?
Can you also show us the previews of the node outputs?
You may need a list of lists.
Marcel is correct- the points need to be in a sublist
Add a list.chop, with a length of 2
This is happening because you are selecting a single edge.
If you selected multiple edges, they would be in sublists by default, no chop necessary
Andrew
Thanks Andrew and Marcel,
The list chop node is the solution.
Thanks!
