Hi @Arun_Prakash, thanks for sharing. Just wanted to know if we have any other method to solve the same as when ever i run this script my laptop hangs even for generating pipe on one line
Hi @chuongmep and @T_Pover
I have tried both MEPover and OpenMEP and think that i did everything correct.
No matter what i have tried i could not get the diameter ( or width/height for duct ) implementing in the script.
All the other things ( location, pipe type, system type ) is correct.
But both scripts creating pipes/ducts with a default size, not the size i made as input, and returns “null” instead of pipe or ducts.
I tried different type of numerical inputs as diameter.
Can you help me to understand what is wrong?
Hi @10urunmaili , can give me show detail capture of warning ?
Can give me see the current unit of the project and information of your pipe when you draw by manual ?
Could it be something related to the decimal seperator,
Which makes python to not get correct?
I need check the issue first, if you can please provide a revit file sample .
As i am a new user here, it does not let me upload the revit file as attachment.
But if it helps I just started a new project with Revit 2023 Metric Systems template, and try to use these scripts to decide the modeling technique.
you can try upload your file facing with issue here : https://upfiles.com/, please include dynamo file also
After re-installing it has been solved… Thank you.
Very nice and useful script by the way… Congratulations on that also.
Cheers
Hello, I’m trying to install the OpenMEP package, but I download and install the package, but it doesn’t appear in dynamo. Do you know what I can do?
Guys, I followed the entire discussion and tried to generate pipes through these 2 nodes, I didn’t try through OpenMEP because I’m having problems with its installation. But even after following the entire discussion, both nodes have the same problem, does anyone know how I can solve it?
if you use mepover nodes be sure you have dynamoironpython package installed as well …if in 23-24 use 2.7 ver. 2.5
