so my script works without error
- i have my lines
- pipes
- a system
a.s.o.
but it resulted in cero , whats way out?
the pipes first need to be connected, the should be place line by line…
or have i to filter out line which are too short.
KR
Andreas
PyDWGSetPipe.dyn (21.0 KB)
sovitek
2
Hi Andreas …i guess you miss pipetypes…
sovitek
4
hmmm does it work if you feed in ootb nodes and probably lacing longest
@sovitek ,
could the problem be also a units-convertion-issue ? becaus diameter results in an error… it is for civil
KR
Andreas
sovitek
6
arhh ok…can you show what you select, and what happends if you feed in a diameter by codeblock
@sovitek
my input are dynamo lines i filter them
a pipe
KR
Andreas
@sovitek ,
here is the code, but i think there is no issue, only thing that is suspect: in the transaction the brakets [i%ll].
clr.AddReference("RevitAPI")
if isinstance(IN[0], list):
lines = IN[0]
lines = [IN[0]]
FirstPoint = [x.StartPoint for x in lines]
SecondPoint = [x.EndPoint for x in lines]
if isinstance(IN[1], list):
pipetype = UnwrapElement(IN[1])
pipetype = [UnwrapElement(IN[1])]
ptl = len(pipetype)
if isinstance(IN[2], list):
systemtype = UnwrapElement(IN[2])
systemtype = [UnwrapElement(IN[2])]
stl = len(systemtype)
if isinstance(IN[3], list):
level = UnwrapElement(IN[3])
level = [UnwrapElement(IN[3])]
ll = len(level)
if isinstance(IN[4], list):
diameter = IN[4]
diameter = [IN[4]]
dl = len(diameter)
elements = []
for i,x in enumerate(FirstPoint):
try:
levelid = level[i%ll].Id
systypeid = systemtype[i%stl].Id
pipetypeid = pipetype[i%ptl].Id
diam = diameter[i%dl]
pipe = Autodesk.Revit.DB.Plumbing.Pipe.Create(doc,systypeid,pipetypeid,levelid,x.ToXyz(),SecondPoint[i].ToXyz())
param = pipe.get_Parameter(BuiltInParameter.RBS_PIPE_DIAMETER_PARAM)
param.SetValueString(diam.ToString())
elements.append(pipe.ToDSType(False))
except:
elements.append(None)
OUT = elements
@sovitek ,
i think i got it i was feeding it with MEP Systems instead of MEP System Types
Another way with Open MEP
See document : Class Pipe | Open MEP
@chuongmep ,
how to install? in the folder there are
KR
Andreas
Hi @Draxl_Andreas , you can follow tutorial here : How to install OpenMEP package | Open MEP . Install to use is more easier than develop it.
