I’m trying to create a builders work floor plan showing pipe/ Duct penetrations in the floor slab but there are some horizontal pipe/duct still visible that are outside of the view range. Domestic pipework does not show up but soil pipes do, it’s the same with ducts, some are visible and others aren’t. View range is set 20mm about and 20mm below the slab with the cut plane at 1200mm to show room furniture etc
Is there a way to overcome this with dynamo?
