I need to prepare a statement. For each pipe, in addition to its parameters, I need to provide the number of the parcel of land on which it is located. I have the plots in the form of shp files. I don’t know how to go about this and what package I will need for this.
I am attaching the Dynamo file and the CAD file.
In the future I will have to do the same with the characteristic line.
Saving to Excel as I have the lists I will take care of myself.
Hi @Gif
Can you attached example drawing
As an idea
Maybe you can set parcel number in description pipe
If the pipe under 2 parcel …
And looking at this
I added all the files to dropbox
The pipe sometimes crosses two parcels of land and sometimes it does not. If it crosses then I need information about two parcels of land and if not then one.
No, I don’t have a solution.
Nor do I have any idea
Hi @Gif,
What you’ll probably need to do is something like this:
- Get the geometry of the parcels into Dynamo
- Get the 3D line/curve geometry of the pipes
- Project the pipe geometry down onto the XY plane (so they are co-planar with the parcel geometry)
- Figure out which pipes intersect with each parcel boundary (the Geometry.Intersect node is a good place to start)
The problem turned out to be the selection in the settings of area extra large.
