Civil 3D Pressure Pipe Network Nodes Problem!
Any Help please ? I have tried to change geometry scale from medium to large and also extra large same null result ? where is my fault ?
hi
@ingenieroahmad
If possible, draw an example
Hi @ingenieroahmad . I faced this issue too and I solved it by accessing the whole list of pipes that you have (there is a specific node for that) and then I got from that list the pipe I am interested in. You´ll need to replace the code block.
Can you put some nodes with result out, please?
I Feel that there is a problem due to pressure pipe element !!! Because the same nodes work fine with pipe network not pressured one.
@Paolo_Emilio_Serra1 Your help will be appreciated .
@ingenieroahmad the Camber package has nodes for Pressure Pipe Networks that might work.
I download it and it works fine, But there is no nodes for pipes curves or solids like Civil Toolkit !!
Hi, I hope this can help Accessing pressure network - #17 by Drbohlav
What version of Civil 3D do you have?
I work with civil 2021 , dynamo 2.5 ,civil toolkit 1.1.30
Can you confirm that you have the latest update for Civil 3D?
Try to update your Civil 3D to 2021.3 Autodesk - Account
I recommend also AutoCAD and Map 3D updates
I will try and give you feed back. Thank you :slight_smile:
Hi
If the update does not work for you,
Use Python
Can you write up the code part of python ?
yes
import sys
# Add Assemblies for AutoCAD and Civil 3D APIs
clr.AddReference('acmgd')
clr.AddReference('acdbmgd')
clr.AddReference('accoremgd')
clr.AddReference('AeccDbMgd')
clr.AddReference('AeccPressurePipesMgd')
clr.AddReference('acdbmgdbrep')
clr.AddReference('System.Windows.Forms')
clr.AddReference('Civil3DNodes')
# Create an alias to the Autodesk.AutoCAD.ApplicationServices.Application class
import Autodesk.AutoCAD.ApplicationServices.Application as acapp
# Import references for Civil 3D
adoc = acapp.DocumentManager.MdiActiveDocument
ed = adoc.Editor
civdoc = CivilApplication.ActiveDocument
PROFILE_VIEW = IN[0]
def move_labels(PROFILE_VIEW):
	if not hasattr(PROFILE_VIEW, "__iter__"):
		PROFILE_VIEW = [PROFILE_VIEW]
	error_report = None
	res = []
	resp = []
	resf = []
	resa = []
	try:
		with adoc.LockDocument():
		    with adoc.Database as db:
		            sampleLineId = PROFILE_VIEW[0].InternalObjectId
		            objVIEW = t.GetObject(sampleLineId, OpenMode.ForWrite)
		            for i in  objVIEW.GetPipeIds():
						objpp = t.GetObject(i, OpenMode.ForWrite)
						resp.append(objpp.Name)
		            for i in  objVIEW.GetFittingIds():
						objpf = t.GetObject(i, OpenMode.ForWrite)
						resf.append(objpf.Name)
		            for i in  objVIEW.GetAppurtenanceIds():
						objpa = t.GetObject(i, OpenMode.ForWrite)
						resa.append(objpa.Name)
		            t.Commit()
	except:
		import traceback
		error_report = traceback.format_exc()
	if error_report is None:
		return [resp,resf,resa]
		return error_report
OUT = move_labels(PROFILE_VIEW)
السلام عليكم
اعمل متل الصورة الي فوق مهندس احمد
Continue via PressurePipeNetwork Members
Help
The PressurePipe.Curve node has its own programming
The python node output is string and it’s not valid data type to continue with my graph. we need the output to be PressurePipe as a datatype to go on.
