Pipe run to polyline
Hello community,
Anyone know how to convert the pipe run to a polyline?
puh… i found this:
Here’s a way to do it. You can use dynamo geometry to then redraw a polycurve. The node from the toolkit give a 3D poly based on the centerline (not the invert) I believe. You can then use C3D’s built in tools to convert to 2D poly if needed.
Pipe to Polyline v0.dyn (21.2 KB)
EDIT: Just realized you might be talking pressure pipes, if so I haven’t tried yet.
