I am trying to perform an action, in this case disallow the curtain wall join ends, but I want this action to be performed in the current view only as it would take a very long time to do it in the full project file and someone might be working in other areas of the building and will need (most likely) need to sync every time a run the script.
#Start of generic stuff imports
#import Revit API
clr.AddReference(“RevitAPI”)
#import Revit Elements
#import DocumentManager and TransactionManager
#get current Revit document
#End of generic stuff imports
#Unwrap input
inputs = UnwrapElement( IN[0] )
curtainWalls =
#Initiate counter
n = 0
#Get only curtain walls from input
for e in inputs:
try:
elementType = doc.GetElement(e.GetTypeId())
if elementType.Kind == WallKind.Curtain:
curtainWalls.append(e)
n = n + 1
except:
print(“not curtain wall”)
#Start Transaction
for e in curtainWalls:
Autodesk.Revit.DB.WallUtils.DisallowWallJoinAtEnd(e, 0)
Autodesk.Revit.DB.WallUtils.DisallowWallJoinAtEnd(e, 1)
#End Transaction
#Wrap results
OUT = ["Disallowed joins on walls: " + str(n), curtainWalls]
Is there a way to do this?
PS: the whole script is from https://www.engipedia.com/disallow-joins-on-curtain-walls-with-dynamo/
Thanks in advance
