Filter Visibility
Apologies for the amount of posts being posted about this, but I can’t seem to find one with a straight forward answer…
I’m not that experienced at Python, so alas, I cannot alter the stuff posted in others to suit my own. I have a list of true and falses to indicate the value of the visibility, I need to use them to set the visibility in a view dictated by me.
I’ve seen a few python scripts around, i’ve also seen Konrads thinkparametric.com link to his files, but the files will not work for me.
I think the closest python script so the one I require is this:
If anyone could help out, or point me in the direction of something I may have missed, i’d really appreciate it.
clr.AddReference(“RevitAPI”)
import System
dataEnteringNode = IN
filters = UnwrapElement(IN[0])
view = UnwrapElement(IN[1])
visOrNot = IN[2]
output =
for x in filters:
try:
view.SetFilterVisibility(x.Id, visOrNot)
output.append(“Filter switched”)
except:
output.append(“Filter failed to switch”)
OUT = output
Hey,
That Python works only for a single Visibility… You need a zip…
Hope that helps,
Mark
Hello, same problem here. Your solution work fine but for one view at a time.
Is there a way to adapt the script so it could handle multiple views ?
I have just one filter per view but each view have a different filter.
I’d like to turn off the visibility for all filters
I’m learning python but I’m still struggling at the moment…
Hi @ here is a way with ootb nodes
VISIBILITY FILTERS.dyn (69.8 KB)
