Revit API : Walls junction with WallUtils.AllowWallJoinAtEnd()
Hi everyone,
I used the WallUtils method to join all my walls, when I ran my dynamo nothing happened.
You can find in below my script in python :
#Import librairies and Namespaces
import System
import math
clr.AddReference(‘RevitAPI’)
clr.AddReference(‘RevitAPIUI’)
#Document and Transaction
from Autodesk.Revit.DB import WallUtils
from Autodesk.Revit.DB.WallUtils import AllowWallJoinAtEnd
#Define the inputdata
Walls = UnwrapElement(IN[0])
#Creating a variable doc which set the active Revit application and document
#Start the script
#By default all walls are allowed to join at ends, so this function is only needed if this wall end is already disallowed to join.
#If this wall is a stacked wall, all subwalls at this end will be allowed to join.i=0
for wall in Walls:
w=WallUtils.AllowWallJoinAtEnd(wall,0)
Thank you for your help :slight_smile: !
Any changes to model must be done within transaction
Yes, I put it but it’s the same problem :frowning:
import System
import math
#Start the script
for wall in Walls:
You probably want to use JoinGeometry. WallUtils only controls autojoin at wall ends. You should reconsider if you want to join walls geometry in your graph. Jeremy Tammik explains this in his post here.
