my script for any reson counts any view, but i want only the currient one (active)
import sys
import System
clr.AddReference('RevitAPI')
clr.AddReference('System')
active = FilteredElementCollector(doc,doc.ActiveView.Id)
OUT = active
KR
Andreas
Why are you using a FEC when you’re already getting the active view directly from the document? What are you trying to do?
@Nick_Boyts ,
i just want the current view, to feed isolate elements
But you already have it here:
@Nick_Boyts ,
yes but i got all views listed… … and revit collabsed!
currView = doc.ActiveView
Just use active = doc.ActiveView. You’re literally getting the active view and then saying filter for this view that I’m supplying.
@aaronrumple ,
thats it! minimal as possible
OUT = doc.ActiveView
Even more concise.
OUT = DocumentManager.Instance.CurrentDBDocument.ActiveView
Hi, the designscript version isn’t bad either
Document.Current.ActiveView;
cordially
christian.stan
@christian.stan ,
hmmm… it does not work
i get a non pointer
Try with Revit document…
