Path of travel, how to visualisize in python
i want to compare path of travels from view to view! project leaders are suspecting that the paths ar not identical, and i want to check this…
my code tragigly shows nothing, only empty lists
i want also a geometry of my path, how ?
clr.AddReference('RevitAPI')
clr.AddReference('System')
activeView = FilteredElementCollector(doc, doc.ActiveView.Id)
paths = activeView.OfClass(Analysis.PathOfTravel).ToElements()
times, speeds, lvls, views, fromRoom, toRoom = [],[],[],[],[],[]
for r in paths:
	time = r.get_Parameter(BuiltInParameter.PATH_OF_TRAVEL_TIME).AsDouble()
	times.append(time)
	lvl = r.get_Parameter(BuiltInParameter.PATH_OF_TRAVEL_LEVEL_NAME).AsString()
	lvls.append(lvl)
	view = r.get_Parameter(BuiltInParameter.PATH_OF_TRAVEL_VIEW_NAME).AsString()
	views.append(view)
	startLoc = r.get_Parameter(BuiltInParameter.PATH_OF_TRAVEL_FROM_ROOM).AsString()
	fromRoom.append(startLoc)
	endLoc = r.get_Parameter(BuiltInParameter.PATH_OF_TRAVEL_TO_ROOM).AsString()
	toRoom.append(endLoc)
OUT = activeView, paths, times, lvls, views, fromRoom, toRoom
KR
Andreas
If I recall the error on the Element.Geometry method has to do with the arrowhead. As such you can call for everything except the same item at the same index of the list.
To do so via Python would be the same as any other element: elem.get_Geometry(Options()) if memory and capitalization serve.
