Hey there,
Following that post everything is almost perfect, but I have a new problem that requires your help :
Using archi-lab nodes to create filter rule and parameterfilter, I have a problem to create rules using “is less than” operator. As you can see, I’m creating two filters that are slightly the same apart that one is using “is greater than” and the other uses “is less than”.
Both of them seems to be created in my filter list, but when I want to open “Test_TXT is less than” Revit keeps crashing. “is less than” is the only ruletype that crashes my Revit.
Does anyone has faced that problem and maybe has a solution to fix it ?
I can’t really rely on archilab to create filter if that rule is not working, and using orchid/archilab depending on the rule we want to create is do-able but not very optimized.
