opening in floor by curves node does not work …
Please help me.Thank you in advance!
Hi @naoto
I don’t know exactly where is the problem and I had a lot of mismatch with your file so I started in a separate file.
it appears that if you extract the python script out of the dynamo node it should do the trick.
I hope this could help you.
Regards.
Thank you for your kindness.
I’ll try
This is usually because the depth of lists isn’t what the node expects. Try adding or removing a list depth (via List.Flatten or List.Create) and see if that prevents the need to pull out the python.
It worked by using list.create.Thank you very mach!!!
