when create floor in revit input boundary and automatic open on floor but in dynamo you need poly curve and dont open in floor who can in dynamo input line and convert to floor
Check out my package called Crumple, which has a node which can make floors by lists of curves for openings being included. It will work from 2022 onwards.
See here for similar thread with sample code:
Make the list 1 level deeper and ensure all curves are coplanar. If you havent installed ironpython2.7 package you need that as well.
In a month or so will be a fairly major update.
If you have a Github repo where I can fork a build I might check some 2025 stuff for you next week (while doing similar for a few other packages of mine and others). Feel free to DM.
At this point im still on the IP2.7 train, but this contains half of my wip family nodes. Set parameter is old but most other familydoc nodes set:
I know the switch to net8 fries my excel nodes due to forays in rhino 8. Hopeful that otherwise it will survive the version leap. I’m likely to adopt ZT down the line vs CP3 but C# is very much early days still.
0 testing in 2025/net 8 so for all i know its all kaput. I’m very much leaning on IP in some flavour for now though.
