Is it possible to use Dynamo (dynamosandbox) with an older version of Autodesk Robot Structural Analysis? Specifically, the 2017 version.
I just came across this project, I would like to know if I will be able to combine the two programs. In newer versions of ARSAP Dynamo functions as an add-on, I don’t know if this is possible in 2017?
Autoreply2:
However, I am stuck, I have some questions and I am asking for your help.
Is the Dynamo version important to work correctly with ARSAP 2017? I tried the simplest example (two nodes and a bar) and I get an exception: Autodesk.LibG.LibGPINVOKE. I suspect that I should use an older version of Dynamo.
I am just starting out, so my questions may be trivial…
I’m looking for information on the errors I’m running into and it looks like the problem is in the missing libraries that come with Revit or Dynamostudio, for example:
In any case the errors seem to be the same. So without Revit I can’t do anything? All in all, it’s even hard to find the installation file for the older version
