Offset bounding box curves individualy
Hi all is there a way to offset lines individually???
all i want is to be able to offset 1 line in X axis and one in Y axis
How can i separate them from list ???
Regards
Sorted thanks
Regards
Hi
How did you do it?
Probably using, “get item at index” and isolating the 2 curves required.
Hello
a solution with a list of custom vector and Geometry.Translate
@wihibyusuf
it is better to create a new subject rather than digging up an old one :wink:
I know… ill do that in the future.
I cant seem to see where you add the distance from the curve. Could u post a graph where you do this for example on a curtain wall?
Pleace to hear from you.
The distance of each offset is generated from the amplitude of the individual vectors inside the code block.
