How to offset Curves from Surface of Structure Framing element
Hi!
I pick structure framing and get Curves from Surface. I wanna edit Curves but error.
How to offset it.
If create new curve can be offset it ( but not curve of structure framing)
Thank Advance
test offset curve.dyn (34.2 KB)
@manhgt214 ,
i think you have to change listLevel @L2.
To create a loop of lines you have to take firs/rest of items.
KR
Andreas
Hello @manhgt214 not sure but could something help…
Hi Andreas!
This is your solution.
Can be offset this curve by XZ or XY plan ( I think this is offseting by XY plan)
or something probably :wink:
@manhgt214 ,
i can`t detect this kind of error… finaly it works!
Thank you !!!
But can be offset diference value of curve (this is same 25 for 4 direction)
@manhgt214 ,
it is older post … but maybe you can find some input?
Try something here
Capture
Thank you very much!!!
