I get this warning message when trying to create a conic curve with CP,Weights,Knot Curve tool: _Warning: NurbsCurve.ByControlPointsWeightsKnots operation failed. _ Unable to create BSplineCurve from vertices : IBS_KNOT_SEQ_DECREASING – B-spline knot sequence is decreasing (should be non-decreasing) conic.dyn (4.6 KB)
Take a closer look at the node’s description. The minimum number of points is always degrees + 1 and the number of knots is always the number of points + degrees + 1:
