Does anyone understand and can talk me through what this error message means? Thanks
I cannot explain this error message, but this might be helpful:
also, I am guessing you should not be seeing this message and it may be intended for developers, if that is the case it would be a bug and would be great if you could post to github with this issue, if you have a chance to do this can you also show the input curve?
<span class=“author-link”>Thanks Michael, I thought that may be the case.</span>
<span class=“author-link”><span style=“color: #428bca; font-size: small;”>Ritesh Chandawar</span> I haven’t got the rest of the script anymore I moved on too far. However I can recall all it was, was a nurbssurface, that I extracted the edges to curves and then tried to convert them to model curves?</span>
I’m now getting a slightly different error, which reads…
Warning: ModelCurve.ByCurve operation failed.
Curve must be in the plane
Parameter name: pCurveCopy
Parameter name: pCurveCopyModelCurve.ByCurve operation failed.
