Hi All,
I’m probably doing something very simple very wrong,
I’ve got the following Dynamo script to generate spheres based on a CSV list of points. If I run it in an existing Revit model it generates the Spheres properly. However if I run it in a new Revit file all I get is blue unclickable cubes as per this image. I’m not sure what the cause of this is as all the blue cubes are in the correct place, they’re just not generating correctly.
