Hi all
I am facing issue like I am not able to see the Nonica tab in Revit after installing it.
Kindly let me know the solution.
Can I know the default path for Nonica tab
Hi all
Good morning,
Thanks for your message. Just a few questions that may help you out:
Hope this helps.
NonicaTeam
Hi @Nonica.io Thanks for your response.
That is really surprising for us. As it is the first case of this kind that we have seen from thousands of users.
Our Add-In has been tested to always be installed only for the current window user and ask for admin credentials if the current user is not admin (Autodesk App Store standard).
A quick fix for you while we review this further would be to move all Nonica files from the installed location (the one you marked) to the one I mentioned above for your current windows user.
We hope this helps
NonicaTeam
@Nonica.io I have moved the whole folder into the required location but it doesnot work for me. see picture below for your reference
Apologies, we may have not explained ourself well.
The folder of your image (Nonica) should be located in C:/ in any case.
You should move the four files:
AppData is a hidden folder, so you may need to write it directly in the folder path, as you may not see the folder to click in.
Glad to hear! Thanks for marking as solved.
