Hello all,
I need to create a spline that connects through the reference points (for in-place mass). coordinates of these reference points need to be read from excel. I found similar dynamo scripts for adaptive families , but the node for reference points doesn’t work in in-place mass.Can someone suggest a workaround for this?
Hi @Anima_mc and welcome, if you do it within a Conceptual Mass environment then load the Mass to the project, it won’t suit your needs?
@tradelie Thank you. It might work. Curious to know if there are any other nodes for reference points that work in Revit in-place environment.
