Whenever this happens I usually restart Dynamo, Revit or my Workstation…but this has continued even through restarting everything. On a previous thread, it says that I need to update my Dynamo. But I am already in the latest stable version.
Whenever it is in this ‘error state’ I cannot click anything inside Dynamo, either in the node-space or the system buttons (file, etc…).
What do I need to do to make my nodes com back again and prevent this in the future?
Update:
If I start a new drawing, I have functionality of the Dynamo program. But once I try to place a node, it goes back into the ‘error-state’ symptoms.
@3Pinter I do not have access to uninstall, so I tried a repair on 0.9 to see if that would work. But once I did that and restarted Revit, Dynamo was gone…
@Kulkul Unfortunately I cannot open Dynamo on my computer currently, it is completely missing from the Revit toolbar and the Windows files
Uninstall is a requirement. But don’t just uninstall one part - uninstall all things Dynamo - Studio, Core, Revit, and all versions of each. Then run the MS FixIt utility. Then install the one version of Dynamo that is right for you. Your IT guy will need to do this as you appear to not have local admin rights.
