Node to create stair
Hello!
I’m using Revit 2018.2 and dynamo V1.3.2.2480.
I’m trying to create stairs going from a bottom line that would be on a given slab to another higher level with the stair family system of Revit but I can’t find a node that would help me.
I’ve been searching for a solution but there are hardly no propositions on the net.
If you know any nodes or other solutions that would get around my problem, could you please tell me.
I’m a beginner in coding with Python but if it is a solution I’m ready to try ;).
Related topic without a final solution: Nodes to create stair
Find some info :point_down:
Seems you need to create stair components separately.
Oh ok, thank you for this interesting link. I will see what I can manage to do with there exemple.
Hi All,
I am using the same references as @Thom - see below for what examples I’m trying to pull from. I have gotten passed most visible errors - but the stairs do not stay / commit. This seemed to be other users problems but my commit lines don’t seem to be working.
Thanks in advance to anyone with advice.
current code:
from Autodesk.Revit.UI import TaskDialog
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import IFailuresPreprocessor
from Autodesk.Revit.DB import StairsEditScope
from Autodesk.Revit.DB import Parameter
from Autodesk.Revit.DB.Architecture import StairsRun
from Autodesk.Revit.DB.Architecture import *
class StairsFailurePreprocessor( IFailuresPreprocessor ):
	def PreprocessFailures(failuresAccessor):
		return FailureProcessingResult.Continue
baseLevel = UnwrapElement(IN[0])
nextLevel = UnwrapElement(IN[5])
a = StairsFailurePreprocessor()
trans = Autodesk.Revit.DB.Transaction(doc, 'Stair Transaction')
newStairsScope = StairsEditScope(doc, "New Stairs")
newStairsId = newStairsScope.Start( baseLevel.Id, nextLevel.Id)
trans.Start()
#TransactionManager.Instance.EnsureInTransaction(doc)
stairArray = CurveArray()
pt5 = XYZ(0,0,0)
pt6 = XYZ(15,0,0)
pt7 = XYZ(0,10,0)
pt8 = XYZ(15,10,0)
bdryCurves = list()
riserCurves = list()
pathCurves = list()
bdryCurves.append(Line.CreateBound(pt5, pt6))
bdryCurves.append(Line.CreateBound(pt7, pt8))
#riser curves
riserNum = 17
for ii in range(0, 18):
	end0 = (pt5 + pt6) * ii / float(riserNum)
	end1 = (pt7 + pt8) * ii / float(riserNum)
	end2 = XYZ(end1.X, 10, 0)
	riserCurves.append(Line.CreateBound(end0,end2))
pathEnd0 = (pt5 + pt7) / 2.0
pathEnd1 = (pt6 + pt8) / 2.0
pathCurves.append(Line.CreateBound(pathEnd0, pathEnd1))
newRun1 = StairsRun.CreateSketchedRun(doc, newStairsId , baseLevel.Elevation , bdryCurves, riserCurves, pathCurves )
#TransactionManager.Instance.TransactionTaskDone()
trans.Commit()
#trans.Dispose()
newStairsScope.Commit(a)
#newStairsScope.Commit(new StairsFailurePreprocessor() )
#newStairsScope.Dispose()
OUT = newStairsId
-M
references:
Creating and Editing Stairs
