Creating stairs in Dynamo
Hello everyone,
I am trying to create stairs in Revit with a help of Dynamo. Just as exercise but it is not so easy how I expected to be. Unfortunatelly there is not specific built In Node just for stairs.Only what I found to creating elements are the Nodes under Family Instance. So there is a Node with Input Family Type and set up the coordinates.
I was trying to figured out how the structure with stairs really works.What here is Family Type, Family name etc.? I tried in other direction, from run Type to stairs. I got a Family name right but now I have a problem with the Type name. How to get that?
Thank you in advance for your answers :slight_smile:
The elements which defines stairs cannot be built from scratch and have your stair function as you would expect. You need to build them as stairs via the UI or the actionable API method. I am not aware of any node to do so, but there is sample code for creating a new stair available in a few places online, my preferred starting point would be here: Creating and Editing Stairs
You will need to build your own node for this, which can be done by converting that c# code to Python, or by producing a zero touch node.
Thanks Jacob for the link and your answer. Man this is a new world to me.I am not fimilar with Python so maybe I need to start learning it to be able to do what you’re suggesting.I will try it. Thank you…
Hi Jacob,
I try to give a shot at converting to Python the c# code of the link you provided.
I feel I’m close to the target but I’m getting an error when calling the function (see image below)
immagine
The code is below:
# BOILERPLATE
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import System
from System import Array
clr.AddReference("RevitAPI")
#from Autodesk.Revit.DB import XYZ, Line, CurveLoop, StairsEditScope, FailureProcessingResult
# FUNCTIONS
class StairsFailurePreprocessor:
	def PreprocessFailures(self, failuresAccessor):
		#Use default failure processing
		return FailureProcessingResult.Continue
	def CreateStairs(document, levelBottom, levelTop):
		newStairsId = None
		with StairsEditScope(document, "New Stairs") as newStairsScope:
			newStairsId = newStairsScope.Start(levelBottom.Id, levelTop.Id)
			with Transaction(document, "Add Runs and Landings to Stairs") as stairsTrans:
				stairsTrans.Start()
				# create a sketched run for the stairs
				bdryCurves = []
				riserCurves = []
				pathCurves = []
				# create points
				pt1 = XYZ(0, 0, 0)
				pt2 = XYZ(15, 0, 0)
				pt3 = XYZ(0, 10, 0)
				pt4 = XYZ(15, 10, 0)
				# define boundaries
				bdryCurves.append(Line.CreateBound(pt1, pt2))
				bdryCurves.append(Line.CreateBound(pt3, pt4))
				#riser curves
				riserNum = 20
				for i in range(0,riserNum+1):
					end0 = (pt1 + pt2) * i / riserNum
					end1 = (pt3 + pt4) * i / riserNum
					end2 = XYZ(end1.X, 10, 0)
					riserCurves.append(Line.CreateBound(end0, end2))
				# stairs path curves
				pathEnd0 = (pt1 + pt3) / 2
				pathEnd1 = (pt2 + pt4) / 2
				pathCurves.append(Line.CreateBound(pathEnd0, pathEnd1))
				newRun1 = StairsRun.CreateSketchedRun(document, newStairsId, levelBottom.Elevation, bdryCurves, riserCurves, pathCurves)
				# add a straight run
				locationLine = Line.CreateBound(XYZ(20, -5, newRun1.TopElevation), XYZ(35, -5, newRun1.TopElevation))
				newRun2 = StairsRun.CreateSketchedRun(document, newStairsId, locationLine, StairsRunJustification.Center)
				newRun2.ActualRunWidth = 10
				# add a landing between the runs
				landingLoop = CurveLoop()
				p1 = XYZ(15, 10, 0)
				p2 = XYZ(20, 10, 0)
				p3 = XYZ(20, -10, 0)
				p4 = XYZ(15, -10, 0)
				curve_1 = Line.CreateBound(p1, p2)
				curve_2 = Line.CreateBound(p2, p3)
				curve_3 = Line.CreateBound(p3, p4)
				curve_4 = Line.CreateBound(p4, p1)
				# append the curves to the landing loop
				landingLoop.Append(curve_1)
				landingLoop.Append(curve_2)
				landingLoop.Append(curve_3)
				landingLoop.Append(curve_4)
				# create the landing
				newLanding = StairsLanding.CreateSketchedLanding(document, newStairsId, landingLoop, newRun1.TopElevation)
				stairsTrans.Commit()
			# a failure preprocessor is to handle possible failures during the edit mode commitment process.
			newStairsScope.Commit(StairsFailurePreprocessor())
		return newStairsId
# INPUTS
startLevel = IN[0]
endLevel = IN[1]
# CODE
app = uiapp.Application
sfp = StairsFailurePreprocessor()
# OUTPUTS
OUT = sfp.CreateStairs(doc, startLevel, endLevel)
Any help would be appreciated to solve the issue (and provide me and my friend Damir getting a new custom node :wink: )
Thanks in advance
P
Oooo there is Paolo, the Master of Python hehe…Thank you Paolo for your effort finding the answer for this script.I appreciate it very much :slight_smile:
Ahah, if I was a true master I wouldn’t be asking for help as I’m stuck :sweat_smile:
Glad to help you in this quest. :wink:
Bye
Paolo
Hi there,
got some steps further with the code and debug it.
I’m at the very end now but I can’t manage to get the FailuresPreprocessor working.
See my updated code below (i left a few commented lines for other unsuccessful tests I did).
# BOILERPLATE
import sys
import System
# FUNCTIONS
	#def PreprocessFailures(self, failuresAccessor):
	def PreprocessFailures(failuresAccessor):
	newStairsId = None
			stairsTrans.Start()
			bdryCurves = []
			riserCurves = []
			pathCurves = []
			# create points
			pt1 = XYZ(0, 0, 0)
			pt2 = XYZ(15, 0, 0)
			pt3 = XYZ(0, 10, 0)
			# define boundaries
			#riser curves
			riserNum = 20
			newRun1 = Autodesk.Revit.DB.Architecture.StairsRun.CreateSketchedRun(document, newStairsId, levelBottom.Elevation, bdryCurves, riserCurves, pathCurves)
			newRun2 = Autodesk.Revit.DB.Architecture.StairsRun.CreateStraightRun(document, newStairsId, locationLine, Autodesk.Revit.DB.Architecture.StairsRunJustification.Center)
			p1 = XYZ(15, 10, 0)
			p2 = XYZ(20, 10, 0)
			newLanding = Autodesk.Revit.DB.Architecture.StairsLanding.CreateSketchedLanding(document, newStairsId, landingLoop, newRun1.TopElevation)
		newStairsScope.Commit(sfp.PreprocessFailures())
		#newStairsScope.Commit(sfp)
		#newStairsScope.Commit(StairsFailurePreprocessor())
	return [newStairsId, doc.GetElement(newStairsId)]
# INPUTS
startLevel = UnwrapElement(IN[0])
endLevel = UnwrapElement(IN[1])
# CODE
# OUTPUTS
OUT = CreateStairs(doc, startLevel, endLevel)
The output is the following:
If I remove the line newStairsScope.Commit(sfp.PreprocessFailures()) the code seems to go fine (I get an ElementId) but no results is showing in Revit and such ElementId is not searchable in Revit either.
See output below:
And Revit warning if I try to access the element by its Id:
immagine
Thanks again for your help.
Paolo
Hehe man in my eyes you’re the master.Thank you again :)…
