Dear All,
I have been trying to create a spiral Stair using the code below. I am feeding in the data as coordinates by using a json file. Even though the drawing created from the data looks correct I am still getting an error message: Cannot finish run sketch. Run sketch cannot have a riser segment intersecting the boundary at more than 2 points.
Any ideas what is going wrong?
Think we will need your python code, pasted as preformatted text to troubleshoot this one.
#define lists
RiserCrv= List[Curve]()
BoundaryCrv= List[Curve]()
PathCrv= List[Curve]()
#Start Transaction
Levels=Fec.OfClass(Level).ToElements()
for level in Levels:
if level.Name=="LevelBottom":
LevelBottom=level
BotId=level.Id
if level.Name=="LevelTop":
TopId=level.Id
newStairsScope = StairsEditScope(doc, "New Stairs")
newStairsId = newStairsScope.Start(BotId,TopId)
tx = Transaction(doc, 'Stairs')
tx.Start()
class StairsFailurePreprocessor( IFailuresPreprocessor ):
def PreprocessFailures(self,failuresAccessor):
return FailureProcessingResult.Continue
# RiserCrv_Create Linesfrom points
for key,values in RiserCrv_1_json:
ln=Line.CreateBound(dXYZ(values[0]),dXYZ(values[1]))
RiserCrv_1.Add(ln)
#create plane from basepoint
Planes_Outer=Plane.CreateByNormalAndOrigin(XYZ(0,0,1),BoundaryCrv_Outer_BP)
Planes_Inner=Plane.CreateByNormalAndOrigin(XYZ(0,0,1),BoundaryCrv_Inner_BP)
Planes_Path=Plane.CreateByNormalAndOrigin(XYZ(0,0,1),PathCrv_BP)
#BoundaryCrv_ Create Arc by points
BoundaryCrv.Add(Arc.Create(Planes_Outer,m2f(BoundaryCrv_Outer_radius),startangle,endangle))
BoundaryCrv.Add(Arc.Create(Planes_Inner,m2f(BoundaryCrv_Inner_radius),startangle,endangle))
#Create PathCrv
PathCrv.Add(Arc.Create(Planes_Path,m2f(PathCrv_radius),startangle,endangle))
#CreateSketchedRun
Stair_1 = Architecture.StairsRun.CreateSketchedRun(doc,newStairsId, LevelBottom.Elevation, BoundaryCrv, RiserCrv, PathCrv)
#End Transaction
tx.Commit()
newStairsScope.Commit(StairsFailurePreprocessor())
