Hi everyone,
I’m trying to create a simple stairs using a python script. The script I have now is functional, however it creates two staircases with a different “actual tread depth” value.
Note that I do not fully understand transactions and processes within python and RevitAPI. I copied some lines of code from the following link: https://forum.dynamobim.com/t/stairs-disappearing-via-python/32952/3?u=pieter.lamoen
This is my code:
# Import libraries
import sys
# Import Dynamo Geometry Nodes
clr.AddReference("ProtoGeometry")
from Autodesk.DesignScript.Geometry import*
# Import RevitNodes
# Import RevitAPI
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import*
from Autodesk.Revit.UI import*
from Autodesk.Revit.DB.Architecture import StairsRun
from Autodesk.Revit.DB.Architecture import StairsRunJustification
# Define Current Document
# Define something???
class StairsFailurePreprocessor2( IFailuresPreprocessor ):
def PreprocessFailures(self, failuresAccessor):
return FailureProcessingResult.Continue
# /// This is where the fun starts ///
# INPUT
baseLevel = UnwrapElement(IN[0])
nextLevel = UnwrapElement(IN[1])
line = IN[2].ToRevitType()
just = StairsRunJustification.Center
# or input1 = UnwrapElement(IN[0])
# CODE
TransactionManager.Instance.ForceCloseTransaction()
newStairsScope = StairsEditScope(doc, 'New Stairs')
newStairsId = newStairsScope.Start( baseLevel.Id, nextLevel.Id)
# TRANSACTION
# Start Transaction
trans = Autodesk.Revit.DB.Transaction(doc, 'Stair Transaction')
trans.Start()
newRun = StairsRun.CreateStraightRun(doc, newStairsId, line, just)
trans.Commit()
newStairsScope.Commit(StairsFailurePreprocessor2())
# End Transaction
stair_d = doc.GetElement(newStairsId)
# OUTPUT
OUT = stair_d, newRun
And this is my dynamo script:
Any help is appreciated! ![]()
