Hi all,
I have a problem with the Tee.By2Mep Curve button. When I try to connect 16 sprinklers to 4 main pipes. When I try to create Tee it returns null. Only done 50%, I can’t fix it.
i fixed it already
I am trying to create Tee, would it be possible to share your dyn file?
You can use OpenMEP package to do that :
CreateTee.dyn (10.5 KB)
Option 2 with input three pipe :
CreateTee2.dyn (7.3 KB)
I have created pipes from an Autocad(CAD) file, however I cannot create fittings like elbows and tee, how can I filter the pipes to create the tee? Any ideas would be welcome, thanks.
I was testing your model and they are great, it would be interesting if you add the pipe size parameter to your create node, it is a recommendation, thanks.
Excellent chuongmep, thank you very much.
Is it possible that from those nodes you can create accessories, such as elbows and tee?
You can, let use some node support in fitting with create newelbowfitting, I think you should open new topic .
Thank you
